Frequent Contributor I
WPA2 AES and TKIP for mobile device
If the wireless device client can't support WPA2 AES, can Aruba controller ask the wireless device client use WPA2 TKIP instead of AES? Which mean by default all wirelss device client will use WPA2 AES, only when it can't support then use WPA2 TKIP.
Can i configure that on the Controller?
Re: WPA2 AES and TKIP for mobile device
The SSID profile, Advanced will show you what combinations you can configure.
Colin Joseph
Aruba Customer Engineering
