Frequent Contributor I
WPA2-PSK Blacklisting issue
I created a WPS2-PSK network with Blacklisting disabled, all works fine.
If I enabled Blacklisting and set the max authentication failures to 5, clients can not connect anymore.
Plus it doesnot seem like the value I put in to max authentication failures is saved. It always reverts back to 0 which is default value.
Screenshot is attached.
I am using Airwave 8.0.6.1 managing the Aruba VC(version 6.4.2.3). Please advise.
Re: WPA2-PSK Blacklisting issue
WPA2-Personal does not have authentication, so there is nothing to blacklist.  Are you doing mac authentication on top of that?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I am planning to do mac authentication...I think it make sense after you mentioned that:)
