WPA2 invalid key using AirWatch on iPhone
Hi all,
I have a client using AirWatch for MDM on corp phones and having issue where iPhones keep asking for password to WPA2-PSK network even though AW profile is setup. in controller i see the key exchange and showing invalid. If we manually type the password then it connects, but if we copy/paste the password into AW and push profile it fails. I don't think its an issue on Aruba config, but could there be something i'm missing? Anybody experience a similar problem and fix it?
#AirheadsMobile
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
