Frequent Contributor II
Wall identification with VisualRF
Have looked in both offline and online versions of VisualRF...
In either version, is there a method to automate the delineation of walls?
This seems like it should be possible.
Unfortunately, whenever we receive blueprint updates, we just receive PDFs. (Not rasterized PDFs btw)
It seems like Aruba gears VRF to work with CAD/DMG files.
Can anyone confirm that with CAD or DMGs, the wall material specifying doesn't have to be done over and over?
Re: Wall identification with VisualRF
Unfortunately, there is not a way to automatically detect walls.  They have to be drawn on all diagrams.
Thank you Colin... can you confirm that to be the case for CAD / DMG files as well?
the.sleeper
It is the same with CAD drawings, as well.
