Occasional Contributor I
Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
Want to set up a wired connection with cisco 3750  switch. Anyone have a sample config for both Aruba and cisco sides?
Re: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
https://ase.arubanetworks.com/solutions/id/93
Thank You,
Troy
Will this only work with ClearPass? I want to use DHCP from the controller.  Does the cisco switch and Aruba controller need to be in trunk or access mode?
are you trying to do .1x, or are you just looking to put a controller in a wired switch
Thank You,
Troy
Not looking to use .1x. I want to connect a 7240 controller with a ciso 3750 switch and have wired customers from the switch obtain an ip address from dhcp on the controller. Thanks
jeffgraham88,
Maybe you can describe further in detail what you are trying to do.  Connecting a switch to a physical port on a controller is routine.  Creating a DHCP pool on the controller for that subnet and enabling it so that it gives out addresses is also routine from a switching perspective.  If you connect a 3750 with other switching devices, the configuration is the same on both the controller and the 3750.  Is there something specific that you are having difficulty with?
Community Manager
This depends on the availabilty you need. If all of you hardwarre is in the same VLAN then access is what you need. If your radius is in lets say a management vlan and you clients live in a client VLAN then in order for them to talk to the radius for authentication you will need the ports to be trunked.
Airheads Community - The best place to Connect. Engage. and Learn.
