Warehouse APs (IAPs) and Brackets help
Hi there,
I am looking for help in relation to picking APs for warehousing. I do not know which would be best option..I have attached a picture of the warehouse. Do you need certain type ogf APs that will have a connection for direct line of site antennas?
What type of APs work best in warehouse environments?
Any help much appreciated
Regards
Prodigy
Re: Warehouse APs (IAPs) and Brackets help
Please see the presentation here:  http://community.arubanetworks.com/aruba/attachments/aruba/tkb@tkb/92/1/Airheads%20Barcelona%202010%20-%20RF%20Design%20for%20Retail%20Warehousing%20Manufacturing.pdf
As long as your space has controlled temperature, any omnidirectional downtilt access point would be good.  The AP-315 is a good value.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi there,
Many thanks for the information. Incidentally, do you have any suggestions for mounting brackets and Antenna? Which ones would conform with the IAP 315s
Kind Regards
Prodigy
The AP-315s have built in antennas, so you would not need to select external antennas.  They also come with mounting equipment, so you would just need to find or fashion mounting brackets based on what you would want to mount them to.  The installation guide for the 315 AP is here:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=29608
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/21953/Default.aspx
