Wave 1 and Wave 2 WIPS difference
  • 1.  Wave 1 and Wave 2 WIPS difference
    Posted Nov 10, 2017 10:43 AM
    Dear All,
    My question is the following:
    Is there any restriction in the WIPS activity in case we use wave 1 AM APs in Wave 2 environment?
    I mean for example a 205 AP used in AM mode can't detect the Wave 2 client that connect to Wave 2 Rogue AP or do any malicious activity.
    Every difference is interesting.
    Thank you,
  • 2.  RE: Wave 1 and Wave 2 WIPS difference
    Posted Nov 10, 2017 10:59 AM
    There's nothing special about a Wave2 AP in terms of how they communicate on a protocol level that would be obscured from a Wave1 AP. Unless there are vulnerabilities exposed in the MU-MIMO component of the AP-Client communication (which to my knowledge there isn't), an 11ac Wave1 AP as a pure WIDS sensor should be able to monitor a Wave2 environment without any gaps.
  • 3.  RE: Wave 1 and Wave 2 WIPS difference
    Posted Nov 13, 2017 04:05 AM
    Hi jhoward,
    Thank you for your answer.
    I remembered that the Wave 2 AP can use 160 MHz wide channel but Wave 1 AP only can use 80 MHz wide channel.
    Is not that a problem ?
    Best regards,
    tkpeter
  • 4.  RE: Wave 1 and Wave 2 WIPS difference
    Posted Nov 13, 2017 04:13 AM
    AP management traffic still uses a single channel even when bonding (40mhz/80mhz/160mhz), and the management channel is what is monitored for WIDS/WIPS.  That does not change in a 160 mhz wide channel.
  • 5.  RE: Wave 1 and Wave 2 WIPS difference
    Posted Nov 13, 2017 04:28 AM
    Hi Joseph,
    Very thank you.
    Best regards,
    tkpeter
