Wave 2 and wave 1 access points same floor
Hello
There isnt any problem if i mix wave 2 and wave 1 acess points
Ill have 225 and 325 in the same floor mixed.   Is that a possible deployment that wont give any issues?
I ask this because 802.11ac and 802.11n on the same floor was not recommeneded
Cheers
Carlos
Alternetworks Corp
Re: Wave 2 and wave 1 access points same floor
That should be fine at this time.
Hello
Why do you say at this time? This colud change?? I mean that in the future for se reason it cold not be ok?
Alternetworks Corp
If client drivers later on start preferring or weighting W2 APs, then it will matter, but for now that has not really been seen or been an issue so long as proper design guidelines are followed in terms of coverage, AP power, etc.
Jerrod Howard
Collin, howard
Thank you very much!!!!
Cheers
Carlos
Alternetworks Corp
