Trusted Contributor I
WebCC
  1. Is WebCC still free with PEF licensing?  If so, any details on when this will become a subscription and cost?
  2. How does WebCC scale on various platforms?  Is there a request per second rating or something similar?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: WebCC
Nothing is published yet so you shouldn't likely see an answer, but I PM'd you as I "know" you and can likely share. Anyone else needing to know should reach out directly to your local account team.
Jerrod Howard
Re: WebCC
So I guess the old saying is true, "it's not what you know, but who you know."  Thanks Jerrod.
