Regular Contributor II
What APs works with Client Match?
I went to one of the Airheads Local events and they mentioned that some of the APs cannot run Client Match. One person said that the AP-125 cannot run Client Match, but some one else said yes it can. I just trying to figure out if it is yes or no.
Aruba
Re: What APs works with Client Match?
The AP-125 does work.    802.11n adn 802.11ac APs should all work.
AMFX | ACCX | ACDX | ACMX
And to add to this, we have been getting tremendous feedback from our customers on ClientMatch.  It works and works well.  I very good benefit to upgrading.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Seth...Do you know when 6.3 will be in the General Availability instead of Early Deployment?
I'm hearing from my SE contact very very soon...within a month if all goes well.. Still too early for me period.
