Frequent Contributor II
What Will happen If I have 2 Controllers 1 Master and 1 Local and Master fail?
Now I will Discuss with you a Scenario to help me in  I have 1 Master Controller and I local Controller now by default the LMS IP for all access points is the Master IP what if I put in Back up LMS the IP of the Local and Master fail then does the access point will work on local noramally?
Re: What Will happen If I have 2 Controllers 1 Master and 1 Local and Master fail?
As long as the APs are able to reach the controller and you have enough licenses on that local controller
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I belive the local controller would take the master role in that scenario. However, the AP's might need to power cycle before they can locate the new master.
Thanks for replay,so now the local will be master or it will remain local?
It will remain a local
Thank you
Victor Fabian
