Frequent Contributor II
What is mesh Config Tool?
What is Mesh Config tool and how can I use it?
Re: What is mesh Config Tool?
2014-05-23 15_10_53-d1x3hnhct7p62q.cloudfront.net_SupportSite_ProductionFiles_594788b2-0ffd-40af-811.png
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I have the manual. How do I get the software downloaded?
sdf
You would need to register for a support account using the serial number or PO of your hardware.
Jerrod Howard
sdf
Packaged software sent me mail, thank you.
1771467655@qq.com
