Can you provide a use-case where you would want to set this up?
Our ap system-profiles have always been set to "allowall" for the session-acl. Someone inadvertantly removed this and it defaulted to "ap-uplink-acl" which ended up breaking wireless-to-wireless communication on the same VLAN between clients. Everything else seemed to be functioning normally.
Why would removing this ACL cause this behavior?
