Frequent Contributor II
What is the Required to get Aruba Location Services work in Aruba (Controllers and APs) System?
Now I have already APs and Controllers installed in a specific factory and I have the Autocad files for the place how to get Locations Services work on Mobile Devices and thanks
Re: What is the Required to get Aruba Location Services work in Aruba (Controllers and APs) System?
You need AirWave for VisualRF location mapping.
Tim Cappalli | Aruba Security
Dear Tim,
First of all thank you and second thing that I know About airwave but I Mean this :
http://www.arubanetworks.com/pdf/products/DS_LocationServices.pdf
I can see that I shoul lug USB in each AP but many APs doesnt have USB port and also use Aruba Battry powerd Beacons and also I should use Merdian Editor so can you inform me how to do such a solution and thanks
Beacons aren't currently available. More information will be published closer to the release date.
Thank you so much for your informations brother
