Frequent Contributor II
What is the best scenario to design and configurations for VOIP coverage?
as per VRD for configurng for cisco phone 792x series the inital role is logon and some one before told me to use VOIP role now what is the best to use?
Re: What is the best scenario to design and configurations for VOIP coverage?
What type of authentication are you using ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
WPA2
All you need is the default 802.1X role or the default psk to be the VOIP role
Thank you
Victor Fabian
Ok now I will teill you the scenario  I have cisco access point already deployed and aruba deployed after that and the profiles on IP phone Cisco 792x series is WPA2 PSK and in aruba same security now what is the best scnario to roam normally between cisco and aruba ?
also what is the good distance between each access point aruba for indoor and out door .
It won't roam properly between the two , no information will be exchange between the two systems . Once
And the assoc / Auth and the keying process will have to start all over again.
To avoid any issues you should have those separated .
Thank you
Victor Fabian
We are in situation where customer ask for this as one of his requirments so what do you suggest to achive best option
Unfortunately, this cannot be done. You will need to explain to the customer that it is two different vendors and you will not be able to roam between the two.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
