Hi All
What is the difference between AP215 and AP225?
I see there is only one 1GB interface for AP215, so how can it achieve 1.3g as stated in datasheet.
Mahathma
225 is for high density and it has 2 ports this one might have better CPU
215 is for moderate density but has 1 port,
There is no way you will achive 1.3gbs, you will just achive 1gbs cause of the port that is missing.
Other vendors are doing that, if you check Cisco 3700 series is the same. It just has one 10/100/1000 port. http://www.cisco.com/c/en/us/products/collateral/wireless/3700-series-access-point/data_sheet_c78-729421.html
Cheers
Carlos
AP225 is supported from the 6.3.x code, whereas why AP215 is supported from the 6.4.2.x code?.
We understand the AP215 is lesser capable than the AP225.
Can support for AP215 provided in 6.3.x code?
As far as specs, the 215 has a slightly less memory than the 225, so in theory it can handle less users when stretched to capacity (say into 75+ users per AP). But otherwise performance is fairly similar with normal user loads.
