What is the difference between a campus AP and RAP in functionally?
What is the difference between a campus AP and RAP in functionally? I.e.: ARM
And About ARM, APs will scan environment and choose channel itself or send information to controller let controller to choose?
Archer
Re: What is the difference between a campus AP and RAP in functionally?
For a Campus AP or RAP , ARM will perform the same channel/power adjustments (ARM Calculation) based on what the AP/RAP obtains from its off-scanning times
Thank you
Victor Fabian
Lead Mobility Architect @WEI
