Occasional Contributor I
What is the difference between the AP-220-MNT-W2 and AP-220-MNT-W3?
What is the difference between the AP-220-MNT-W2 and AP-220-MNT-W3? Can't find any info on the AP-220-MNT-W3 mounting acc.
Re: What is the difference between the AP-220-MNT-W2 and AP-220-MNT-W3?
The "W2" is end of sale.  The W3 is a lower profile version of the W2:  http://www.arubanetworks.com/assets/support/EOS_mountkits_160731-1.pdf
Let me see if we can get you an image of it..
Aruba
The main difference is that the W3 version is almost half the height compared to the W2.
Note that the W3 only comes in white.
IG is attached.
/Onno
Thx for the info
