What is the different between l2 mobility and l3 mobility
Hi All,
I would like to understand what is the different between l2 mobility and l3 mobility. Thanks in advance
Re: What is the different between l2 mobility and l3 mobility
l2 mobility is roaming between controllers where the client vlan is present on both controllers
l3 mobility is roaming between controllers where the client VLAN is not present on the second controller.  Typically a GRE tunnel is built back to the first controller so that the client can continue to pass traffic with the same ip address.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
