Frequent Contributor I
What keyboard key allows panning (navigating) while drawing in walls?
Using VisualRF (thru a browser), trying to designate wall material types...
Seems like once I click on the Draw Wall command, I can no longer "pan" around my floorplan.
(cursor appears as white hand, allows user to center where they are viewing)
Is there no keyboard key I can hold down to give me back this ability temporarily?
Moderator
Re: What keyboard key allows panning (navigating) while drawing in walls?
Unfortunately there's no key.  This is something that would make a good feature request to help enhance the usability of the wall drawing tool.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Thank you Rob.
Just curious, does the non-browser version of VRF allow more control?
(I've heard its very difficult to design browser apps that allow fine grained control for the user.)
Moderator
I like your thinking, but the VisualRF code in AirWave is almost exactly the same as in VisualRF Plan (with some changes to allow it to stand alone).  The main benefit being a new feature or bug fix on one is also implemented on the other, so they should both be parallel aside from the timing of releases (usually an AMP release comes first, with a VisualRF Plan release trailing if needed).
Rob Gin
