Frequent Contributor I
What to see when an AP achieves 60 concurrent clients?
Hi everybody.
This week we have a new situation for us. An AP 125 achieves 60 concurrent clients many times a day.
No one is complaining. But I need to know how is the wifi health in this location. What I need to look for?
We have AP 125 with 3200 controller at 6.1.3.7 version and Airwave 7.5.7.
Re: What to see when an AP achieves 60 concurrent clients?
Create a trigger or connected clients in Airwave.
Tim Cappalli | Aruba Security
Ok, but what commands and metrics on controller say if this AP is busy, if I need more APs to support more clients?
The controller doesn't keep historical information. You would use the daily capacity report that's built into airwave.
Now, this AP is with 52 authenticated clients. What commands do you suggest to see the real time wifi health in this location?
You should really use Airwave to look at the AP...
