Whats the difference between 274 vs 275 vs 277 in layman's terms?
I know all 3 are meant to be outdoor APs.
I basically want to know if I have this part straight in my head. (not sure if I'm right or wrong.)
275 = omni directional non removal antennas
277 = directional non removal antennas
274 = removable mix and match antennas
Re: Whats the difference between 274 vs 275 vs 277 in layman's terms?
That's correct
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
That's correct
Get Outlook for iOS
Thank you
Victor Fabian
