When I hook up my APs, they are not recognized by the controller. Syslog message below.
When I hook up my APs, they are not recognized by the controller.  The syslog indicates: ncftpget e500.ari  server said: No such file or directory.
Is it missing software or license files??  What is it complaining about.
Re: When I hook up my APs, they are not recognized by the controller. Syslog message below.
What AOS are you running and what type of APs you are trying to attach ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
AOS 6.1.3.6
AP105
APIN0225
Les.
murrayl wrote:
AOS 6.1.3.6
AP105
APIN0225
Les.
Murray L,
The minimum code version for AP225 is 6.3.  Please upgrade your controller and try again.  http://www.arubanetworks.com/pdf/products/DS_AP220Series.pdf
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
As cjoseph pointed out you need to upgrade to 6.3 to support 225 , that message is an indication that the AP is not able to upgrade since it can't perform the FTP to load the AOS.
Are you also experiencing this issue with the AP105 too or just for the 225 ?
Thank you
Victor Fabian
Both.
Murray L does this controller work for ANY access points at this time?
