NDA
When controller OS 6.3.1.2 and IAP OS 6.4.x.x, can convert IAP to Campus AP?
When controller OS 6.3.1.2 and IAP OS 6.4.x.x, can convert IAP to Campus AP? or must be the same level OS?
Re: When controller OS 6.3.1.2 and IAP OS 6.4.x.x, can convert IAP to Campus AP?
Each IAP has the minimum level of controller code needed to convert that AP on its datasheet under "Minimum Software Versions"
NDA
Hello Colin,
I recently try to convert IAP to Campus AP.
But failed to convert :( and i get pop-up message error in attachment
Hey, what model of IAP and controller is this?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
NDA
Aruba Controller 650
IAP-215
Hey, please refer to the IAP 215 datasheet (http://www.arubanetworks.com/assets/ds/DS_AP210Series.pdf) the minimum supported ArubaOS is ArubaOS 6.4.2.0
ACMA, ACMP, ACSA
NDA
Ouw okay.
Btw, can you help me send ArubaOS™ 6.4.2.0 to my email? (nadamaulana@live.com)
I m just end-user and dont have permission to download ArubaOS.
Today i try to register but need a few days to approval my account.
So if you help me send this OS, i m very thank you :)
