Where can i get firmware for an AP-105
Where can i download the actual firmware for an AP 105. The controller is remote and i need to setup a local TFTP server and therefore i need to publish the firmware locally on the TFTP server. I just need the link or URL to the download as i can not find it on the support website.
Super Contributor I
Re: Where can i get firmware for an AP-105
You would need to acquire the firmware from a working controller. There are a few articles on how to extract it
ACDX #419 | ACMP |
if your AP is Aruba Remote AP , you have just tu publish your controlleur TFTP port (by the same way that you have do with the IPSEC port), the AP will automaticly download Firmware.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
