Where to download old VRD: Retail wireless networks VRD? Look like it has be removed on Aruba web.
I need the retail wireless networks validated design.pdf file. Thanks for help.
Re: Where to download old VRD: Retail wireless networks VRD? Look like it has be removed on Aruba w
I will send you via PM.  This was publicly available at one time, so I'm sure is fine.
ACCP, ACCX #817, ACMP, ACMX #294
Hi Mike,
I would like to get this VRD as well if its possible to share
Regards
Gurpreet
That VRD has been deprecated for quite sometime.  Is there a specific design that you are looking for that is not covered by the other VRDs?
That guide had some useful info on Various devices used in warehouses , Maximum output , Bands supported, etc
That table was a sample worksheet that only had 5 devices:
thank you, Is there any other guide which focuses on the warehouse best practises.
http://community.arubanetworks.com/t5/Airheads-Breakouts/Hostile-Environments-Wireless-LAN-Design-for-Warehouses/ta-p/247147
