Whitelist
What are the capabilities/limitations with using whitelisting and is there a way to set a time limit on when the whitelist is no longer valid?
Re: Whitelist
Which whitelist are you referring to?
Tim Cappalli | Aruba Security
Re: Whitelist
At this point CPSEC and RAP.
Re: Whitelist
There is no expiration time, no.
If you offload to ClearPass, you could, however, build policies around time.
Re: Whitelist
Thank you.
