Contributor I
Why I have link quality on mesh routers with 83% even when they are totally close?
I have noticed that all mesh routers best link quality is 83%..is that is normal?
Aruba
Re: Why I have link quality on mesh routers with 83% even when they are totally close?
On MeshOS, 83% is effectively 100%.   You will never see 100% due to the way the quality algorithm is constructed.
83% is very very good.
-cl
