Why do we nees to set a static value for RX of a radio
 Hi all
Why do we nees to set a static value for RX of a radio ?
What is the optimized value ?
Re: Why do we nees to set a static value for RX of a radio
All the Radio Parametere execpt Antenna gain , are managed by ARM (Adaptative Radio Managmenet), it optimise you Radio Infra.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
supporsbt wrote:
 Hi all
Supoorsbt,
I am not sure there is a place to set the RX on a radio.  Please attach a screenshot so we understand what you are referring to..
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
