Why does not the Antenna Parameters option value exist when I set it to GUI in 6.5.4.2?
I use the controller 7205, and the OS version uses 6.5.4.2.
I am using the AP314 and I want to manually input the gain value of the external antenna
Like the image, there is no gain item on the GUI screen.
Does anyone have similar problems?
Re: Why does not the Antenna Parameters option value exist when I set it to GUI in 6.5.4.2?
Try clearing your browser cache to see if it fixes it.
 Thanks for your reply.
I changed the operating system and the related symptoms disappeared.
