Contributor II
Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.4GHz
I opened up an IAP-275 to look at mounting options on a portable site survey kit and noticed that of the 6 antennas, 2 are shorter. These 2 short antennas are both 5GHz antennas (5G1 and 5G2). The 2.4GHz antennas are all large ones. Is there a reason or what's the difference between these antennas?
MVP
Re: Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.
There are two V-pol and one H-pol antenna per radio (3 antennas per radio). The H-pols require a different design than the V-pols, so they are different sizes.
Jerrod Howard
Sr. Techical Marketing Engineer
Contributor II
Hi jhoward,
How come is there a difference between the 2.4GHz and 5GHz? So the 2.4GHz has different antennas?
Tom
MVP
Different frequencies means different length of antennas to maintain the same gain (which is why you will often see dual-band omnis that have different gains depending on 2.4Ghz or 5Ghz). And yes, each radio has three antennas, 2 V-pol and 1 H-pol antenna (v-pol is vertically polarized, h-pol is horizontally polarized).
Jerrod Howard
