Contributor II
WiFi calling in ArubaOS 6.5
I have a question why we need to configure Wi-Fi Calling on the controller in 6.5? We are currently running 6.4 and both android as well as iphones can make calls using wifi? A user can disable the celular network and makes calls without any configurations in the controller. I just want to know more about the benefits of this feature in 6.5
Thank you in advance,
Nils
Re: WiFi calling in ArubaOS 6.5
http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Voice_Video/Extended_Voice_and_Video.htm?Highlight=wifi calling
Wi-Fi Calling Support in ArubaOS
ArubaOS provides QoS for voice calls made using Wi-Fi calling. ArubaOS can identify and prioritize calls made using Wi-Fi calling. UCM provides visibility for all voice calls made using Wi-Fi calling."
Occasional Contributor I
Colin are you saying that WIIF calling has to be enable in 6.5.  I was just about to post a question related to this.  In previous version, we did not do anything and wifi calling worked fine, now I have users complaing of one-way calling and call drops.
Can you re-send the link I am getting " Sorry. That page isn’t here anymore."
I corrected the link.  Please try it again.
Hey cjoseph,
Other than enabling wifi calling and adding DNS pattern information what else should be configured QoS? We are are using AP225 and it is a very small network at the moment with 8 APs. Back in the summer when we were running 6.4 we didnt have any issues with wificalling. I have disable this feature and still get the same results. Any suggestions or should I just open a case?
IMPORTANT NOTICE: This message may contain privileged and confidential information and is intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission.
It might not make a big difference unless there is alot of congestion on your network.  If there is congestion, priority could make a difference in terms of voice quality.
