Contributor I
Wifi Auto-Configuration Tool with hidden ssid
Hi all,
Is there anyone know what is the command for enable "Connect even if the network is not boardcasting" with Aruba Wifi Auto-Configuration Tool ?
Re: Wifi Auto-Configuration Tool with hidden ssid
That checkmark is when the SSID is hidden.  If you want to hide your SSID,
(config)# wlan ssid-profile <name>
      (config)# hide-ssid
I would recommend against this practice however.  Is there a reason you wish to do this?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor I
Our customer want to hide the SSID base on their security policy.
And they want to let the wireless users can setup the wireless profile on their device with one click.
They create the bat file with the command as below:
ArubaWifiCfg_Vista.exe -add /SSID:WiFi /Authentication:WPA2 /Encryption:AES /EAPType:PEAP /InnerAuthentication:GTC /EnableFastReconnect:TRUE /ValidateServerCert:FALSE >NUL
But it won't enable "Connect even if the network is not boardcasting".
Group policy is the best way to do this.  The autoconfiguration tool does not have that switch.
Group policy does not have an EAP-GTC option.  Are you also using EAP-GTC?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
Yes, we're using EAP-GTC.
