Occasional Contributor I
Will Centralized Licensing work across a VPN between two sites - To upgrade %26 save licensing fees
customer curently using 2 3600 over a VPN as master / Master, and wiondering if we do a controller upgrade, could we have a Centralized Licensing model and just transfer non-built in licenses ?
Saving $$$$ for existing customer
Re: Will Centralized Licensing work across a VPN between two sites - To upgrade %26 save licensing f
Yes as long as you allow UDP/8211
Thank you
Victor Fabian
Lead Mobility Architect
Will they still work as master / master just sharing the pool of licenses ?
Yes
just need to point the master that doesn't have the licenses to the other master (License Server)
Thank you
Victor Fabian
