pmonardo is correct if your 800 controller fails this won´t be redundant but I think you just want to test and in that case I´d say this should work fine.
Make sure the VLAN that will be used with VRRP is propagated to both controllers (ping eachother) and make sure that the AP, if on another subnet, can route to the VRRP VLAN.
