Occasional Contributor I
Will electric fan motor cause interference to the Aruba Access Point ?
MVP
Re: Will electric fan motor cause interference to the Aruba Access Point ?
Not usually no, unless it's some large, high voltage special kind of fan. Spectrum analyzer would be a good start if you think there is an issue.
Jerrod Howard
Sr. Techical Marketing Engineer
