Will two RAP3s work behind the same ISP NAT?
Is there any issue with having two RAP3s on the same broadband connection creating an ipsec tunnel back to the same controller?
Re: Will two RAP3s work behind the same ISP NAT?
As long as your router can pass more than one iosec connection, you should not have a problem
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
