Wired Policies
Is there any menu in Aruba Controller to allow a user connected to ethernet port of Access Point, if there is no policy defined for this?
Re: Wired Policies
Hi Kristjon,
Please provide more information regarding the requirement.
By default , port 0/1 on the AP are enabled.
E0 acts as uplink while rest of them are generally used as downlink unless you are using E1 for uplink as well (AP LACP).
By default, there is no authentication mapped to E1 port.
Controller based AP's:
Instant AP's:
