Wireless AP CPU and Memory Triggers and Reports
I've been trying to use the memory and CPU utilization triggers and report for wireless access points.  It works great for the controller but doesn't seem to work for the APs.  AP - Procurve MSM422, Contoller - MSM760.  Is there a compatiblility issue?
Moderator
Re: Wireless AP CPU and Memory Triggers and Reports
Will try to get someone to replicate this with some devices in our lab.  Some devices do not provide CPU / Memory data for AMP to trigger against.  Will update with more info after testing.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
[ Edited ]
Memory and CPU Utilization reports and triggers can be generated only in the controller level.
We do have AP options in them but that is for FAT AP's and some iOS devices.
Jeyashree
Are you saying that if the AP was in standalone mode, Airwave would be able to do CPU and memory triggers?
Yes exactly. We dont get these statistics from thin ap's and so we cannot generate alerts or reports.
Thansk,
Jeyashree
