Occasional Contributor I
Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
Hi I have a Aruba IAP-105 deployment and I have to determine best practises to report daily issues, weekly, monthly, quarterly and yearly issues/reports
what should I be reporting?
Super Contributor I
Re: Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
Do you have airwave server? If yes there are some useful reports for your reference.
Normal Guy
If no Airwave, maybe send out syslogs and/or SNMP Traps to another NMS to which you can run reports against.
You would have to analyze those unfortunately.
Your best bet is Airwave and/or Central.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Super Contributor I
Just take note if you want comprehensive reports then get AIrewave else Ceentral will give you "simple" reports such as
Network Summary
Security Summary
PCI Compliance Summary
Normal Guy
