Wireless Bridge with AP 175 and Cisco Switches
I am in need of help or guidance.
I am trying to create a wireless bridge/mesh to a remote Cisco switch that does not have a backhaul.
I have two AP 175s, one is in Mesh Point and one is Mesh Portal.
The switches I am connecting to are Cisco 3750x
I can Ping both APs deployed.  I cannot ping the remote switch or see any traffic coming across.  Management VLAN turns up but not pingable.
The Far side Switch port is set to Trunk
The Near side Switch port is set to a access port.
What am I missing?  Is it a Provisioning issue at the controller or a config issue at the switches.
Tim
