Wireless Client to get IP from Radius ??
Is there a way to enforce the controller to set the IP for the user based on farmed ip address on radius, as opposed to a dhcppool set on aruba controller?
We have framed IP address set for each user under AD profile, so wish IAS to enforce this IP as oppsoed to the controller using a DHCP pool.
At the moment i have a dhcpool in a range for IP set for Vlan50, so its getting an IP from DHCP.
How to make this pickup Radius IP instead, and once done do a route injection to OSPF so its routable on the LAN.
We do this for remote access VPN (not aruba), but cant seem to do it for aruba wireless
