Wireless Controller client dashboard
We have recently migrated our IAP infrastructure to CAP infra with a 7010 controller. We are using the same SSIDs with the same settings. We have a WAP2 PSK SSID mainly used by guests. On the IAP system we could see the hostaname of the device, phone which is connected. On the controller dasboard / Clients view we dont see this anymore only IP address. How can I get back the same functionality?
We have another SSID which is using Radius authentication. For those users we can see usernames.
Thank you in advance!
Gergely
Re: Wireless Controller client dashboard
In the AAA profile, you can enable the "username from dhcp option 12" checkbox to have the username populated:  http://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/aaa_profile.htm?Highlight=aaa%20profile%20opt12
Colin Joseph
Aruba Customer Engineering
Thank you Joseph, this did the trick.
Gergely
