Occasional Contributor I
Wireless Interference
Getting poor quality in many of my AP and the poor quality rotates to different APs. For example AP1 says poor quality then 5 minutes later same AP shows good quality and another APs that had good quality changes to poor.According to Airwave I have something that Airwave identifies as Fixed Feq (vidoe) that is causing the interference. Airwave shows an  appoximation of the location , but I am unable to locate that device .
Any suggestions ?
Re: Wireless Interference
Look for a video camera.  Speak to your security/building maintenance people to see if they put up a wireless video camera.
Thanks. Also, I have another questions. I have an AP92 that is connected to one of my switches
the AP is down and I have the mac , but cannot locate what port the ap is connected to. Check for disable port did  not see any. Is there another to know what port the down ap is connected to?
Sam
