Frequent Contributor II
Wireless client could not print from colubris/hp bridge
We have Aruba 7210 controller with 6.5.3 AOS. here are 25 quantity AP 325 setup.
In our setup colubris and hp wireless bridges connected on wireless network, there are small printers are connected using serial port on bridges.
While wireless client trying to send print command printer could not print at the same time if i connected bridges on wired network wireless client are able to print. This setup was working fine before but today suddenly bridges stop printing over wireless network.
Please suggest how to fix it.
Re: Wireless client could not print from colubris/hp bridge
hi nik-mh, try going into the virtual-ap profile and disable "broadcast-filter arp", then bounce the client in and out of the network once.
