Occasional Contributor I
Wireless connection problem
I'm from South Korea and user of APIN 0205.
First, I'm not good at speaking english.Please understand my english.
I'm going to use BT/WiFi speaker that is controlled by mobile app.
 When I use APIN 0205 to connect speaker, It doesn't work.
(APIN 0205 --(Connect)-->Mobile--(Not-Connect)-->Speaker)
The speaker is recognized as client device on controll screen(Aruba instant).
But When I replace the other AP, It works very well.
(Other AP--(connect)-->Mobile--(Not-Connect)-->Speaker)
I don't know what is wrong.
Please give me some tips for soliving problems
Thank you
Re: Wireless connection problem
Hi JJ,
There could be couple of things which you need to check:
1. Is the client device placed in to a role which has full access ?
2. If the speaker discovery is using multicast, please disable
broadcast filter option in the SSID profile & re-test it.
It works very well now.
I really appreciated.
