Occasional Contributor I
Wireless control to wired Aruba 4604
Hello
Is it possible to use Aruba controller for authentication wired users via captive portal ? For example :
I have some group of PC`s connected by Cisco switch and I want users could authenticate via captive portal on Aruba Os.
Re: Wireless control to wired Aruba 4604
Yes.  You can make that physical port "untrusted".
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Moderator
Once that is complete, set the appropriate aaa profile to the "Wired Access" section of the config.
Ok, thanks
another question is, can I use captive portal to assign user to different vlan ( other than before authentication ) depending on answer from radius nevertheless client is wired or wireless.
I know that cp is layer 3, but is it possible to combine
though ArubaOS supports VLAN derviation
it does not work - for captive portal (has never worked)
