Wireless issue on APIN0215
Hello everyone,
We experience problems with random clients (laptops, smartphones) suddenly loosing wifi connectivity.
During a connection period of about 4 hours, a random client might have 4 or 5 connection problems at which they lose up to 10 pings.
Our setup is made of 10 Aruba IAP-215 Instant AP's with one acting as a virtual controller.
They are running Instant OS 6.4.4. Kindly find the below issues.
  1. Aruba Device getting down frequently
  2. High latency in the traffic
  3. Signal strength getting variation
Please help.
Re: Wireless issue on APIN0215
Do you have broadcast filter ARP enabled on that SSID?
Thank for your response. Yes. We have enabled ARP filter for SSID. Kindly find the attached screeshot.
IT Helpdesk
Somebody please respond
What is the channel utilization on each AP?
You might have to lower the maximum transmit power in the RF> ARM settings for each band that has high (more than 50) utilization.
Please see some ideas here:  http://community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
