I'm trying to get a Verizon U602L USB modem to work with a RAP-105. The USB modem isn't in the select list and I've tried to follow examples of what others have tried with different modems to no avail.
The Vendor ID is 1410 and the Product ID is 9020. I've verified the modem works on a Windows machine.
The following settings are set:
Check the USB Parameters checkbox.
Device - Other (Any)
Device Identifier - 0x14109020
Cellular NW Preference - auto
Link Priority Ethernet - 0
Device type - ether
Link Priority Cellular - 0
To test, I'm plugging in the ethernet port. The RAP shows in the controller. I pull the ethernet port, assuming the USB modem will take over. It doesn't reconnect. Does anyone have any suggestions on how to debug this?
Robert
