Wireshark capture
  • 1.  Wireshark capture
    Posted Jun 29, 2012 04:24 PM
    Is there a way I can decrypt captures taken from a SSID that's using eap-tls authentication?
    I got the RAP streaming data capture to my pc running wireshark w/ ERM support. I do get the packets but they are encrypted. (see attachment)
    My goal is to determine what exactly my client (iPad) is talking to over the internet.
    ckc
  • 2.  RE: Wireshark capture
    Posted Jun 29, 2012 04:32 PM
    The capture you have attached does not show any user traffic, encrypted or not... it's all management frames (at least when I view it on my tablet here).
    When i have encrypted networks the easiest way I typically use is to port span/mirror after the traffic leaves the controller .   e.g. at the egress interface/trunk.   There are other ways, but this works all the time.
    JF
  • 3.  RE: Wireshark capture
    Posted Jun 29, 2012 04:36 PM
    BTW, a quick way to understand where the iPAD (or any client) is communicating would be to issue a  ' show datapath session table | include x.x.x.x '
    If the client is 'tunneled' to the controller this command will show you all the traffic as it arrives/departs from the controller from the client at ip address x.x.x.x.
    Handy, if all you want to do is understand what destinations that iPAD is going to for a first cut.
    You will notice all Apple devices communicate to 17.x.x.x   (The Apple mother ship) on a routine basis.  That is usually an eye opener for many that didn't know that natively happens. ;)
    JF
  • 4.  RE: Wireshark capture
    Posted Jun 29, 2012 06:23 PM
    Thanks for the tips JF.
    ckc
